1984 Chevy Blazer TIMING
89,000 MILES • V8 • 4WD • AUTOMATIC
CHEVYBLAZER84
I CAN'T GET THIS THING RIGHT. I HAVE THE TIMING AT 4 DEGRES ABOVE TOP DEAD CENTER LIKE IT SAYS TO. WHEN IDALING IS FINE BUT PUT IN GEAR AND GIVE IT GAS AND IT FALLS ON ITS FACE. WHAT COULD BE THE PROBLEM
Nov 4, 2008 at 12:42 PM
RHALL77
  • 3,361 POSTS
did you disconnect the brown wire plug in before you timed it
Nov 5, 2008 at 2:23 AM
CHEVYBLAZER84
[quote:7c6c0b7be1="rhall77"]did you disconnect the brown wire plug in before you timed it[/quote:7c6c0b7be1]
no i did not what wire are u speeking of
Nov 5, 2008 at 12:10 PM
RHALL77
  • 3,361 POSTS
its either on the fire wall on the passenger side. its a one wire connector, or its located on the passenger floor where the carpet starts
Nov 6, 2008 at 7:45 AM
