1984 Chevy Blazer Leaking antifreeze
112,111 MILES • V8 • 4WD • MANUAL
DONCLARK
My truck started leaking antifreeze. It appears to be leaking from the front of the intake manifold in the gasket area. It is leaking pretty quickly. Is this a common place for this old 350 engine to leak from? Could you tell me something about this? Thank You
Mar 2, 2008 at 2:23 PM
PEAR69
  • 1,482 POSTS
Congradulations!! You are the 7 billionth or trillonth person to have this problem....lol
Yes this is a common problem. I am suprised, it seems that you never had this problem with this truck after over 20 years. All kiddin' aside you should fix this problem soon because it will only get worse and the coolant leak could began (if it hasn't already) to leak inside of your motor. If this happens it will cause catostrophic engine failure..
Mar 2, 2008 at 7:31 PM
