1984 Chevy Blazer
LVOPIE
Engine Mechanical problem
1984 Chevy Blazer V8 Two Wheel Drive Automatic
i had water come out my tail pipe went and started replaceing the head gastget when i took out the bottom row of bolts i had water come out everyone of the holes is that bad or what
Mar 30, 2010 at 4:04 AM
RHALL77
  • 3,361 POSTS
thats normal. just make sure you seal the bolts when you go to put it back together. did you pressure test the engine before you took it apart
Mar 30, 2010 at 8:02 AM
