1984 Chevy Blazer
SHEILAREYNOLDS5
Electrical problem
1984 Chevy Blazer 6 cyl Four Wheel Drive Manual
when i shut the key off it kind of still runs and back fires trough the carborater
Jun 12, 2009 at 12:53 PM
BILLYMAC
  • 2,204 POSTS
Hi Shiela. sounds like the eng is idleing too high. this usually causes run on.. you have to find out if you have a vacum leak under the hood. if not then you have a idle control prob .. good luck hope this helps billymac
Jun 12, 2009 at 2:16 PM
