1983 Chevy Blazer Turn Signal Fuse Location
274,382 MILES • V8 • 4WD • AUTOMATIC
TMHANES
Where is the turn signal fuse located on a 1983 K5 Blazer 4x4? I assume it is in the fuse block under the steering column but I need to know which fuse number slot the fuse is located?
Thanks
Dec 9, 2009 at 9:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Fuse # 8 (15-Amp) located in fuse block behind a cover in the dash to the left of steering column.
Dec 9, 2009 at 10:44 AM
