1982 Chevy Blazer Surpentine conversion
1982 CHEVROLET BLAZER
100,000 MILES • V8 • 4WD • AUTOMATIC
BLAZER
I have a 82 blazer and have installed a 91 chevy 350 with 98 chevy heads. I used a surpentine drive drive system from a 91 firebird and I run into a problem I lost the crank pully so what I did was I found one frome what I thought was a 87 chevy blazer with a surpentine set up and now all but the crank pulley lines up. There is a 1/4 inch differance with the crank. It is to far back and it wont line up. Is there a differance between the truck and Firebird lower crank pulleys? If not is it year? What can I do?
Oct 19, 2008 at 7:45 AM
BLACKOP555
  • 10,386 POSTS
dont put that pulley on, get a aftermarket one desigend for tha tvehicle. if you sce up the balance its going to destroy th bearings and the engine. do it right.
Oct 19, 2008 at 8:15 AM
