1982 Chevy Blazer
80,000 MILES • V8 • 4WD • AUTOMATIC
JMONTANO6
I have a 82 chevy Blazer and it will not start. I changed the distributor cap, rotor, module and coil. Thinking it might be the electronic ignition or some thing to do with it. But no luck, I did put in gas treamant in the tank the day prior to this happening. I tried starter fluid and no luck. I'm running out of ideas now. I hope you can help me.
Thanks
John
Jul 21, 2010 at 10:57 AM
  • 75,988 POSTS
Inspect and test the distributor pick-up coil resistances and for short to ground
Jul 21, 2010 at 11:15 AM
