Firing order?
STEPHENR1128
I need the spark plug wiring diagram for this vehicle. having trouble with misfire after installing new wires. need to make sure wires are put back correctly.
Feb 20, 2009 at 3:14 AM
  • 55,682 POSTS
Hello, my information showed this for the 2000-4.3-vin X and K. Firing Order 1-6-5-4-3-2
https://images.2carpros.com/forum/automotive_pictures/170934_chevy_blazer_1.jpg
Please let us know if you need anything else to get the problem fixed. Cheers, Ken
Sep 20, 2017 at 9:24 AM
CHRISTEIXEIRA
Whats the Firing Order on 1999 Chevy Blazer 4.3l engine
May 14, 2021 at 5:34 AM (Merged)
  • 55,682 POSTS
Here is the firing order for your car 4.3 v6 engine. (below)
Cheers, Ken
KEITHPRIVETT
Spark plug wire diagram?
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_firing_order_1.jpg
The info showed this for the 4.3.
MWILDER75
what is the number 1 position on distributer cap?
  • 75,988 POSTS
At 5 O clock position-see below
WRENCHTECH
  • 20,760 POSTS
This picture might be easier to read.
MWILDER75
Thank You for your help this worked
IAMGRAYSONC
I changed spark plug cables and distributor cap and think I have them installed in the wrong order ?
HMAC300
  • 48,601 POSTS
Here is the ignition system firing order for your truck 1-8-4-3-6-5-7-2 pic included. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
DANNY L
  • 5,648 POSTS
Glad to hear this information helped. Thanks for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
BRYANTD
what's the firing order for a 1992 chevy s10 blazer 4.3
  • 55,682 POSTS
Firing Order .................... 1-6-5-4-3-2 . Please let us know if you need anything else to get the problem fixed.
EDWARD BECCO
i need to see a diagram on how to put the wires in order
May 14, 2021 at 5:35 AM (Merged)
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_fo_95.jpg
REDLOVER8
my father passed away a few years ago and left his jeep in the garage. it doesnt run. it turns over but wont start. i am getting fuel and air so my next area to look is spark. he put a 4.3L from a '93 chevy blazer into it. it has a tbi but i dont know if that came with the engine or not. i have searched the internet and found some websites for other year engines. but i would like to know for that specific year where the spark plug wires go. basically what terminal on the distributor attaches to what spark plug. thank you for your time. Josh.
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_chevy_blazer_2.jpg
Hello, I came across the above picture. I'm not sure I trust pictures? You can put the number one cylinder on tdc of compression stroke, then whichever coil tower the rotor is pointing at or leading into, is the number 1 tower, you can see the firing order and direction of rotation on the cap. Did this vehicle run after the engine change-over?
BRYANTD
Just did a tune up and can't remember the firing order on my vehicle. any help would be much appreciated.
  • 110,248 POSTS
Welcome to 2CarPros.
Not a problem. Here is the firing order:
IGNITION FIRING ORDER
The attached picture shows cylinder location.
Picture 2 shows wire routing and if you look at the distributor, it indicates which wire goes to each cylinder.
BRYANTD
thanks for the help it worked
  • 110,248 POSTS
You're very welcome. It is an easy thing to have happen. Take care and let us know if you have questions in the future.
Good job,
BRYANTD
Would the parking sensor cause my bmw 528i 2008 from starting?
  • 110,248 POSTS
Welcome back:
No, that shouldn't cause a problem. Most times, it is either a fuel or ignition spark related issue. You need to check to see if you have both. If you do, then we need to look at timing.
Take a look through this link:
If you want to check the two things I suggested, here are links to guide you:
____________________________________________________________________
Here are the specific directions for testing fuel pressure. The attached pictures correlate with the directions.
CHECKING FUEL PUMP DELIVERY PRESSURE
13 31 029 - Checking fuel pump delivery pressure (N52)
pic 1
Special tools required:
- 13 5 220
- 13 5 221
- 13 5 222
pic 2
Important!
The fuel in the fuel lines is under pressure (approx. 5 bar)!
Catch and dispose of escaping fuel.
pic 3
Necessary preliminary tasks:
- Switch off ignition.
- Remove acoustic cover See: Engine > Removal and Replacement > 11 00 ... Removing and Installing/Replacing Acoustic Cover
pic 4
Remove dust cap (1).
pic 5
Connect special tool kit 13 5 220 (comprising 13 5 221 and 13 5 222) to pressure sensor of DIS Tester.
Connect pressure sensor to DIS Tester.
pic 6
Important!
Do not under any circumstances screw in the check valve up to the mechanical stop.
This could damage the valve in the pressure regulator housing.
pic 7
Mount special tool kit 13 5 220 to injection tube and tighten knurled nut hand-tight.
Screw out check valve (1) so that valve in pressure regulator housing is closed.
Start engine.
Screw in check valve (1) until a pressure reading is indicated on DIS Tester.
pic 8
Measuring fuel pressure.
- Select Measurement.
- Multimeter function appears
- Select Pressure test
- Read off value of fuel pressure.
Compare actual value of test pressure with specified value .
Switch off engine.
pic 8
Note:
Removing special tool kit 13 5 220:
- Switch off engine
- Screw out check valve fully again.
- Remove special tool kit 13 5 220 from pressure regulator housing.
- Catch and dispose of escaping fuel.
pic 8
Note:
Read out fault memory of DME control unit.
Check stored fault messages.
Now clear the fault memory.
I just realized this is for a different vehicle. If you have further questions related to it, I need you to start a new thread. We are trying to keep them specific to one car and problem so it helps others. I'm sorry about that.
Regardless, in the next thread you start, make sure to indicate if you checked these things and what was found.
JOEL1983
What is the correct spark wire sequence to this chevy.
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_187.jpg
1986 CHEVROLET BLAZER SUV
When I start the truck it started to back fires and shakes real bad and turns off I think my spark plugs wires are placed wrong. Or my have the firing order wrong some one place help
CJ MEDEVAC
  • 11,000 POSTS
remember # one's position on the distributor cap may vary depending on how you install the distributor
Wherever #1 winds up---that is the starting point for the sequence
Thank you I hope this works and I will be sure to keep you posted
Dose it matter if the spark plugs wires are placed in the wrong order?
CJ MEDEVAC
  • 11,000 POSTS
Very much.
The Medic
Not in wrong firing order but , just the sparke plug wires in general?
GENDY
I need the spark plug wiring diagram for this blazer. having trouble with misfire after instling new wires. need to make sure wires are put back correctly.
  • 75,988 POSTS
Here you go
https://images.2carpros.com/forum/automotive_pictures/12900_fo_blazer_1.jpg
CJ MEDEVAC
  • 11,000 POSTS
You mean the entire wire from beginning to end, got swapped from #6 to # 3-----but is still hooked up correctly in firing order?
The medic
HMAC300
  • 48,601 POSTS
after checking firing order scan for codes and check fuelpressure with a gauge autoparts rent it
BIGCCHEW77
1995 chevy blazer 4.3L VIN W engines Firing order
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_1995_chevy_blazer_Fir_ing_order_2.jpg
