1978 Chevy Blazer Windshield wipers
ADRIANNE323
Electrical problem
1978 Chevy Blazer V8 Four Wheel Drive Automatic 100k+ miles
my windshield wipers come on when I turn on the ignition, I hit the wiper switch but then 20-25 seconds later they come on again, this happens over and over, I have replaced the switch twice, replaced the fuse and finally replaced the wiper motor itself but this has not fixed the problem.
Dec 3, 2008 at 2:17 PM
  • 110,248 POSTS
Hi:
It sounds like a switch problem or a short in the steering column. You'll need to remove the steering wheel and part of the column to try and find it.
Dec 4, 2008 at 8:41 AM
ADRIANNE323
The wiper switch is not on the steering column, it is in the dash and since I have been through two switches i doubt it is a problem with the switch.
Dec 4, 2008 at 8:46 AM
  • 110,248 POSTS
Hi:
Sorry about that, I was thinking it was a newer S10. Regardless, there has to be a short at some point. Check the wires near the firewall that run to the wiper motor.
Again, sorry about that.
Dec 4, 2008 at 10:27 AM
