Without warning after being parked overnight the transmission would make grinding noise when attempting to put in drive or reverse. This is an automatic transmission with transfer case on a K-5 Blazer. Had no problems shifting into drive or reverse with it the day before. Temperature here is 24 degrees and dry air and parked in a garage. (Wisconsin). Not sure if the problem is in trany or the transfer case. I personally never heard grinding noise as if shifting a standard without putting in the clutch (Same sound). [img:4dc7f181d8]http://www.2carpros.com/forum/automotive_pictures/166468_DSC01458_2.jpg[/img:4dc7f181d8]
Hope you can help........
THANK YOU!!!!!
Dylan Barnett
262-349-9363
212 Harrison Ave.
Waukesha, Wiscosnin 53186
THANK YOU!!!!!
Dylan Barnett
262-349-9363
212 Harrison Ave.
Mar 8, 2008 at 1:31 AM
