I turn key on any suggestions will not start
150,000 MILES • V8 • 4WD • AUTOMATIC
SPOT2009
battery is good ground wire is good but do not have any power to anything no radio no fan when i turn key on any sugestions will not start
Jan 16, 2009 at 5:53 AM
MIKE H R
  • 3,094 POSTS
chec to make sure you are getting power off the battery. check the wires by the fuse box under the hood. There might be a loose wire or disconnected. Do you have a static tester. One that is grounded and lights up if you have power. If so check the relays under the hood to see if they have power. My guess is that there is a loose or broken power wire.
Jan 30, 2021 at 1:51 AM
