1969 Chevy Blazer ignition distributor
BLAZINJIMMYS
Engine Mechanical problem
1969 Chevy Blazer V8 Four Wheel Drive Automatic
Today I installed hei in my '69 blazer that had a points distributor. I took the positive from the coil, plugged it into the battery plug-in on hei cap. There was no spark. I unplugged it from the cap and ran wire from battery plug-in to the postive battery terminal. I got spark and it ran but it would not shut off with the key at the ignition. It had to be unplugged at the battery. Second part, in order for it to run, I had to crank my distributor all the way to the right to the point of not turning anymore. I have installed several of these hei's in '69 to '72 chevys without previous problems. What is your suggestion to give me more turning room on my cap and why it won't shut off?
Jun 22, 2008 at 10:07 PM
BMRFIXIT
  • 19,053 POSTS
I could be wrong but the wire you ran to the battery I think you should use the fuse box
and you need a circuit controlled by the ignition switch
test the circuit so it has power on it in two positions of the switch ON and in START position
as for the distributor I would remove it and or check if it a tooth or so OFF
Jun 22, 2008 at 11:02 PM
BLAZINJIMMYS
Thank you so much for your help. I wish I could give you a donation but am unable to due to technical difficulties. I will definitely spread the word about your site as your solution was bang on. Again, thanks.
Jun 26, 2008 at 7:47 PM
