'00 Blazer Fuel Pump
DALMATIANDAD
I replaced the fuel pump in my '00 Blazer 2 weeks ago. The vehicle ran fine until it stalled at a stop sign. Now, the vehicle will not start. It cranks but doesn't start. I can hear the fuel pump run when I turn the key. My question is, how do I check the pump pressure? It's getting a spark, so it should run.
Apr 17, 2007 at 12:29 PM
DE3N8FAN
  • 15 POSTS
it should be on the fuel line between engine and fire wall.(looks like a tire valve.) you will have to borrow a gas pressure guage from a friend or buy one.most auto parts stores dont rent them anymore because ,if someone had contaminated gas it could be passed on to the next renter.good luck.
Apr 20, 2007 at 12:08 PM
LES DANE
  • 52 POSTS
did you change the fuel filter when you changed the pump?
Apr 24, 2007 at 10:05 AM
