Power Steering out
HAVRE
95 Beretta V6, 175,000 miles - My power steering recently went out. It worked when I first started the car up, then there was a smell like something was burning and shortly after I had no power steering. I'm thinking that hopefully it is an issue with the belt, does this sound right? Where should I look for this belt and should it be relatively easy to fix myself? Other sugestiions welcomed as well.
Oct 15, 2007 at 5:09 AM
BOOTDOG
  • 665 POSTS
yes i do believe the belt broke. also find the reason why it broke. look for any pulleys that may have seized causing the break. good luck to you
Oct 15, 2007 at 9:11 AM
