1995 Chevrolet Beretta Cuts Out When Coasting
JASON4201979
I have a 1995 beretta 3.1 motor with 142,000 miles.
I just replaced the cattilict convertor. It is still cutting out when you leave off the gas but does not shut off. It idles fine and runs good what could be causing it to cut out when I am leaving off the gas.
Sep 3, 2007 at 9:59 AM
BLACKOP555
  • 10,386 POSTS
sounds like your idle needs to be turned up a bit to see if it runs better, if not your IAC module or PCV valve could be bad.
Mar 21, 2008 at 10:34 AM
SPADE007
  • 37 POSTS
[quote:1028c725d8="Jason4201979"]I have a 1995 beretta 3.1 motor with 142,000 miles.
I just replaced the cattilict convertor. It is still cutting out when you leave off the gas but does not shut off. It idles fine and runs good what could be causing it to cut out when I am leaving off the gas.[/quote:1028c725d8] check the egr valve
Mar 23, 2008 at 10:26 AM
Suggested Repair
Raise the idle slightly and see if the cutting out improves. If not, inspect the IAC and PCV valve; also check the EGR valve.
Conversation Summary
A 1995 Chevrolet Beretta with a 3.1 engine and 142,000 miles cuts out when the driver lets off the gas but does not stall and otherwise idles and runs well. The catalytic converter was recently replaced. An expert suggested raising the idle and checking the IAC or PCV valve if that does not help. Another reply suggested checking the EGR valve.
