FOXYTIGER
  • 25 POSTS
89 chevy beretta 6 cyl my son took off the brake shoes he drove the car because the brakes locked up so he drove it home with no brakes i had to replace the wheel cyl and the shoes i bleeded the brakes but i seem to have less paddle now than when we did that it had no fluid in it when he drove it home should i have bleed the master cly too or do i just need too bleed the brakes again i almost think i need a new master cyl dont know yet it mite be we didnt bleed them right what do you think thanks
Apr 21, 2007 at 6:45 PM
GWRIGHT74
  • 17 POSTS
if there is no brake fluid in the master cyl you will need to bleed the brake again. you will have to bleed them a lot!!!!!also don't pump the brakes when you do this. open bleeder press brake & hold. close bleeder, then release brake. pumping is not good. say you have 1 big air pocit. you pump now you have a bunch of little pocits. know you have to do double the work. it's easyer to get rid of 1 then get rid of hundreds. you will have to bleed alot because of the master cyl was dry.
May 16, 2007 at 3:52 PM
