1997 Chevy Beretta
APOKNIPOOH
1997 Chevy Beretta
headlight do not work
Feb 14, 2010 at 4:04 AM
JDL
  • 16,098 POSTS
welcome to the forum. I'd have to check voltage and ground at the headlamp assembly. Low beam, the voltage wire is tan. High beam, the voltage wire is light green. Black wire is ground. If no voltage, check wiring circuit from dimmer switch.
You may also need to check voltage to and from the headlamp switch.
Feb 14, 2010 at 4:47 AM
