1996 Chevy Beretta hesitation during acceleration
BIFF2001TOR
Other Category problem
1996 Chevy Beretta 6 cyl Front Wheel Drive Automatic 261KM miles
I have a 1996 Chev Beretta z26 w/ 3100.
A few months ago i got an oil change and replaced the pcv valve, since doing that the car really hesitates while accelerating. it will rev properly and then aroung 2000-2500 rpms it seems to "stick" then it will grab then stick again the car is some what sluggish overall. it ran great before the new pcv. also, the car runs perfect when cold, only kicks in when it heats up. the engine runs great in park or neutral, and the tranny isn't slipping
heres what i've done to try and fix it
3 Different pcv's
new pcv boot
new vaccum line to pcv
new fuel filter
new o2 sensor (bank 1 sensor 1)
dropped the trans pan twice (new filter and gaskit)
replaced the catalyc converter (new exhaust as well)
new mass air flow sensor
Jan 10, 2008 at 12:33 PM
MASTERTECHTIM
  • 4,750 POSTS
nothing to do with pcv valve. just coincidence. first thing id check is the coil towers. remove one plug wire at a time from the coil. i bet you find one terminal rusty or black. if you do replace the bad coil and also change the spark plugs and the ignition wires. let us know
Jan 10, 2008 at 12:40 PM
BIFF2001TOR
hey,
I got it fixed turns out the knock sensor was retarding the timing. the engine has a lifter sound so i guess the knock sensor was picking up on that and trying to re adjust the timing
thanks again for all your help,
Ken
Feb 28, 2008 at 5:54 AM
