1996 Chevy Beretta fuel pump
1996 CHEVROLET BERETTA
HOLDEN L
Engine Mechanical problem
1996 Chevy Beretta 4 cyl Front Wheel Drive Manual
i got the car out the first time this summer drove it for two days and then it just stopped running i reolized that when i turn the key on before i start it i can uselly hear the fuel pump turn on but it don't right now and it starts if i spray some carb and chock cleaner into it but it don't stay running obviousley so my question is that would it be the fuel pump realay or is it something else
Oct 18, 2008 at 5:37 AM
  • 110,244 POSTS
Hi:
It could be the fuel pump relay or the relay itself. If you want to try the relay, it's not too expensive. However if that doesn't repair the problem, you will need to get to the fuel pump to check for power. The pump is in the fuel tank.
Let me know if you have any questions.
Oct 29, 2008 at 6:20 AM
