1996 Chevy Beretta Engine wont Start
141,000 MILES • 6 CYL • FWD • AUTOMATIC
SPOOKY
We have a 1996 Chevy Berette we just been given. It had sat outside all winter - and not been run at all. We tried to start it (jumping it - battery is dead) and it would fire, run for about 4 seconds then die. We got to checking things over and found it had a bad coil pack (1 and 4). Replaced coil pack with new one - then the car would not fire at all (cranks - but doesn't fire). We have both spark and fuel - but are at a loss as to what else the problem could be.
Someone suggested that the headgasket might be blown. Would this cause the car to not fire? Should we start looking for a replacement motor - or keep plugging along with this one?
Thanks!
Jun 25, 2008 at 7:37 AM
EUGENE123
  • 273 POSTS
ok since you have fuel and spark you need to check your compression in all cylinders and also a blowed would not cause the car to not start
Mar 13, 2009 at 3:03 PM
