Please Help. My car has been dying randomly, and then starts right up. The check engine light only came on once and it was my O2 sensor and Emmisons leak. And the when the car goes to shift sometimes it shifts up then back down then to the right gear. The car will work fine for some days then just die 10 times in a day. Took it to the dealer ship and they said it might be the Ignition module and it would cost around 650 dollars to fix. Could the O2 sensor and Emmisons leak do this or is it the ignition module, or something else.
Oct 26, 2009 at 12:25 AM
