1996 Chevy Beretta Dead won't start
96,000 MILES • 4 CYL • FWD • MANUAL
HEAVYCHEVY96
I've been working on this for a little while but I was driving the car winter time in vermont and lost more then half my power and she started plooming out smoke. Got a diagnostic tool it said multipe cylinder misfire and tps switch was bad replaced that didn't work I was told the brain was bad replaced that didn't work. Cylinders 3&4 are getting flooded with fuel and keep fowling out the plugs fuel pump is fine checked fuses getting a yellow flame replaced one of the coil packs fuel filter is fine. Took it to a garage ran good for a week then same thing. I'm at my wits end with this car so please help me I love my chevy
Sep 5, 2008 at 9:08 AM
  • 75,988 POSTS
Check the fuel pressure regulator could be leaking-pull the vacuum hose and inspect for fuel if any the regulator is gone.
Also check the compression/injectors on those cylinders. Recheck coil packs
Cylinders 3&4 are getting flooded with fuel due to its not igniting-
Sep 5, 2008 at 10:10 AM
