Jacobandnickolas: is in reply to.
was told by mechanic ghe checked out fuel regulator and it was good. this is also the same person who said injectors for 3 & 4 were bad and needed replacing at the tune of 500.00, sure. picked up car not running still. swapped 3 & 4 for 1 & 2. injectors apparently fine. did not flood 1 & 2 but 3 & 4 still flooding. lots of. like i had poured a cup of gas in 3 & 4 within 6/7 cranks, even with injectors unplugged and cold start injector unplugged as well. maybe i should check out regulator myself, but not sure how to. the first time this happened the car was towed to diffrent garage only to run fine when it got there. no engine light nothing. car was given tune-up including fuel filter changed. ran great for 2 weeks only to do it again, but this time engine coded to tps being bad, replaced, not the fix. was then told ecu must be bad if giving bad code. replaced ecu. not that either. if fuel regulator was bad wouldn,t i be getting fuel in 1 & 2 as well? stumped/jeff sorry about the points thing, im new here and have none to give as of yet.
Nov 8, 2008 at 2:10 AM
