1996 Chevy Beretta car won't start
BRANDONSCHIERER
1996 Chevy Beretta 6 cyl Front Wheel Drive Automatic
the car seems to be trying to kick over and start but never seems to cetch first time its done this acts like it's out of gas but its not
Mar 22, 2010 at 1:13 PM
  • 75,988 POSTS
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 22, 2010 at 4:06 PM
