1995 Chevy Beretta What's Wrong
134,626 MILES • 4 CYL • 2WD • AUTOMATIC
HECLIAN BERETTA
My Beretta shakes and wobbles and about dies when I am or idling. My friend said it sounds like it is only hitting on 2 cylinders. But he also says it could be my fuel pump is dirty, and I need to put some fuel injection cleaner into it. Also another Problem is the transmission, sometimes it doesn't shift into the next gear and the rpm's shoot up, I don't know what is causing it. Please help, much appreciated!!
Feb 5, 2010 at 9:02 AM
HMAC300
  • 48,601 POSTS
first thing is to see if there are any engine codes. hen replace the fuel filter. After you get the engine running right then tae it to a trans shop to have itlooked at . sounds like it may be worn...
Feb 9, 2010 at 7:37 AM
