1995 Chevy Beretta shakes
180,000 MILES • 6 CYL • FWD • AUTOMATIC
BLING5
my car has been shaking ever since i got ive gotten a alinment after i put bran new tires on it. Then i put new lower control arm bushings in it, new tie rod end and new inner tie rod ends. the ball joints are good. I jacked my car up to see if there were any shaking going on in the wheel hubs or not but it seems tight. i cant figure out what it is. I also put a used rack in pinion in it also. the shaking got worse after i put the lower contol arm bushings in. i even got it alinged after putting all this stuff into the front end. i cant figure this out
Nov 25, 2009 at 5:17 PM
  • 110,248 POSTS
If the alignment is good, and everything is new and in good condition on the front end, make sure the rack is tight. Also, I realize that you got new tires, but they may need rebalanced or could have a shifted belt. There could even be a bent rim. If you rotate the tires. does the vibration change?
joe
Dec 21, 2009 at 1:06 AM
