1995 Chevy Beretta overheat
12,200 MILES • 6 CYL • FWD • AUTOMATIC
BERETTA-RANDY
hi, coolant is up where it should be and temp goes up to about three quarters hot on the idiot guage and then drops down quickly to a little above a quarter if i let it sit and idle for about 15 minutes i dont see the fan kick on? the outside temp. is in the 20's so i dont know if fan would kick on or not? could it just be thermostat sticking? if the thermostat is not working properly would that have anything to do with the fan? thank-you so much.
Feb 14, 2008 at 10:46 AM
BERETTA-RANDY
[quote:13f163695e="beretta-randy"]Other Category problem
1995 Chevy Beretta 6 cyl Front Wheel Drive Automatic 122,00 miles
hi, coolant is up where it should be and temp goes up to about three quarters hot on the idiot guage and then drops down quickly to a little above a quarter if i let it sit and idle for about 15 minutes i dont see the fan kick on? the outside temp. is in the 20's so i dont know if fan would kick on or not? could it just be thermostat sticking? if the thermostat is not working properly would that have anything to do with the fan? thank-you so much.[/quote:13f163695e]
Feb 14, 2008 at 10:48 AM
