1995 Chevy Beretta Low Oil Light
16,000 MILES • 6 CYL • FWD • AUTOMATIC
ANDIEK1987
My car just got an oil change about 2 weeks ago, and now the low oil light is coming on. I can make the light go away though if I let the car run for a minute and then restart it. it is hard to restart the car though. The engine isn't making any odd noises and nothing else seems to be wrong.
Feb 7, 2009 at 2:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
First thing is to check your oil level.. If it is low, it will cause the light to come on. After vehicle has been started the oil has been pushed through the system so on the second start of engine, the oil level appears higher so the light does not come on.
Thanks for using 2CarPros.com!
Feb 7, 2009 at 4:03 PM
