1995 Chevy Beretta intake and head gasket
RWT37
Engine Mechanical problem
1995 Chevy Beretta 6 cyl
I have water mixing with my oil. I have a very small buget I'm working with. Should I just replace the intake gasket because i was told that it was a common problem with the 3100,are should i replace both. ARE should i replace the intake gasket and use steelseal on the head gasket?
Feb 17, 2010 at 4:15 AM
HMAC300
  • 48,601 POSTS
this can be either one. usually the intake gaskets leaked at the end of the manifold. Look on both ends to ee if you an see antifreeze. And yes they had a problem but it was later years no the earlier ones. Yo should really have a pro check it to make sure where the leak is. Alsthough if you replace h head gaskets you will get intake gaskets anyhow. so it's up to you...
Feb 17, 2010 at 9:47 AM
