1995 Chevy Beretta Ignition
193,000 MILES • 4 CYL • FWD • MANUAL
BUBBABOY_6969
I have a 1995 Beretta and one day driving down the highway it started to lose its power. After it then died off I tried starting it but it only cranks but doesn not turn over and start. We hooked up a comp tester but it did not register it. I already changed the Ignition Module, and that did nothing and the fuel pressure is good. Any Solutions!
May 16, 2008 at 12:47 PM
MASTERTECHTIM
  • 4,750 POSTS
do you have compression?
May 16, 2008 at 1:00 PM
BUBBABOY_6969
Yes I do have compression
May 16, 2008 at 1:08 PM
MASTERTECHTIM
  • 4,750 POSTS
ok boss. i know fuel pressure is good but try spraying starter fluid into intake and see if it will run. if it does then we know we have a injector pulse problem. if it does not then check spark by pulling off a spark plug wire and rest it near a ground and crank over engine and watch for spark, if no spark then i woulod suggest replacing the crankshaft position sensor.
May 16, 2008 at 11:22 PM
