1995 Chevy Beretta I put in a new blower motor and it won't
BERETTABOY
Heater problem
1995 Chevy Beretta 6 cyl Front Wheel Drive Automatic
What would cause the motor not to work? The resistor?
Nov 12, 2009 at 2:22 AM
JDL
  • 16,098 POSTS
Welcome to the forum, did you check for voltage and ground at the blower motor connector, hvac turned on, key on? Purple is voltage, black is ground. High speed doesn't use a resistor,but, there is a blower relay. Relay energized, only high speed voltage to blower motor. Relay not energized, continuity for lower speed voltage, lower speeds do use a resistor circuit.
Nov 12, 2009 at 3:13 AM
