1995 Chevy Beretta Hesitation
99,500 MILES • 6 CYL • 2WD • AUTOMATIC
REPTAR022000
  • 10 POSTS
As soon as I try to stay at a constant 50, 55 or higher is bucks and rides like crap. It will be a little sluggish when I try to accelerate also. I did plugs, wires and fuel filter already. I dont know what else it could be. Its AS SOON AS I hit 50 it bucks like crazy. But if I stay at a constant 45, 40, 30 its fine.
May 25, 2008 at 2:09 PM
LEGITIMATE007
  • 5,121 POSTS
I think that you may have a torque convertor problem, are u sure that your wires are in correct order?
May 25, 2008 at 2:29 PM
REPTAR022000
  • 10 POSTS
Yea i tripple checked the wires. Why do you think its a torque converter problem?
May 25, 2008 at 2:33 PM
  • 75,988 POSTS
At 50mph the torque converter lock up should engage-do below if not it were right back to the tranny.
Check the throttle position sensor closed and WOT voltages could be a weak spot on it. Also follow it with a fuel pressure check with and w/o the pressure regulator.
May 25, 2008 at 5:47 PM
MERLIN2021
  • 17,250 POSTS
Service engine light on yet? check codes like this.
https://images.2carpros.com/forum/automotive_pictures/62217_95_OlderGM_23.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
May 26, 2008 at 1:22 AM
REPTAR022000
  • 10 POSTS
There is no check engine light on. Will there still be codes even without the light on? And I also notice that when you first start it up its a rough idle then after a few minutes it will go back to normal. I dont know if that information could help.
May 26, 2008 at 10:39 AM
LEGITIMATE007
  • 5,121 POSTS
there should still be codes stored. but I don't know if you could get that info. doing it the manual way, you may have to have it scanned.
May 26, 2008 at 3:00 PM
CHEVYGIRL1997
i have kinda a similar problem. mine when i get between 50 and 75 mine will act like its stalling when i try to accelerate. then if i let off the gas pedal and re-accelerate its fine for a little. like a bypass of the problem. haven't done a tune up but not quite sure what i need to tune up other than plugs and wires.
Dec 29, 2017 at 9:17 AM
Good Afternoon
Another possible issue could be the cat converter being clogged not allowing the engine to breather. The test is done by removing the O2 sensor and inserting a back pressure gauge to verify.
You could also remove the O2 sensor and drive it and see if it is any better
Jan 1, 2018 at 1:27 AM
