1995 Chevy Beretta fuses
175 MILES • 6 CYL • FWD • AUTOMATIC
GOERTZEN67
is there fuses in the engine compartment that run the engine fan and inside stereo and if so where located yesterday i changed a bad hose on the top radiator and now it still says low coolant and is overheating brand new hose i think its a fuse
Apr 1, 2010 at 12:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the radio/cd player has a separate fuse...it is fuse number 11 (20 amp) in the fuse box, left side of instrument panel. .
for the cooling fan , check for a faulty cooling fan relay which is on the relay bracket, on right strut tower.
Apr 24, 2010 at 7:31 AM
