1995 Chevy Beretta fuel pump power
LWUSNAVY2005
Electrical problem
1995 Chevy Beretta 6 cyl Front Wheel Drive Automatic
i took my harness out and cut the roll over out. put the harness back in and cant get power to fuel pump. nothing is going to it and everything else works. motor turns and everything is hooked up just the fuel pump wont work. grounding is good.
Mar 29, 2010 at 12:51 PM
HMAC300
  • 48,601 POSTS
are you sure it was the rollover that you cut out? probably the computer can't find it so it won' t let it run....or start. Or check to see if the fuel pump relay is working.......
Apr 8, 2010 at 10:39 AM
