1995 Chevy Beretta defroster not blowing air on windsheild
GOERTZEN67
Heater problem
1995 Chevy Beretta Front Wheel Drive Automatic 175000 miles
my car i got for my daughter heats up just fine inside it just doesnt blow hardly any air on the windshield when its on defrost it blows thru the vents and also it has frost inside the windows too
Feb 17, 2010 at 3:07 AM
HMAC300
  • 48,601 POSTS
there is a vacuum or elecric motor that moves what they call a blend door and position door. it may be stuck or it may not work. you can stick your hand up there and feel around and try to move it to see which door you have a hold of. the frost may be a leaky heater core or just cold air coming in creating the frost. the cold air would be coming in due to the blend door stuck/not working.
Feb 17, 2010 at 9:51 AM
