1995 Chevy Beretta clutch fluid
1995 CHEVROLET BERETTA
70,000 MILES • 4 CYL • FWD • MANUAL
CHRIS_GLATZ88
okay,, i have been filling my clutch resivor up everyday.. i was looking around for a leak and there is not one on the master cyilinder or by the slave sylinder but i went under the car and the in clutch fluid leaking out of the transmition,., the is a little whole were i can see fly wheel and it seems to be leaking out of there any idea what it can be,,,
May 24, 2008 at 3:22 PM
MIKE H R
  • CAR REPAIR CONTRIBUTOR
  • 3,094 POSTS
the clutch slave cylinder is leaking inside where the arm pushes out. I would replace it. If too much fluid soakes the area it could get on the clutch pressure plate and cluch disc. causing even more replacement parts.
May 25, 2008 at 8:54 AM
