1995 Chevy Beretta Charging/Altenator Problem
98,500 MILES • 6 CYL • FWD • AUTOMATIC
REPTAR022000
  • 10 POSTS
I have a '95 Beretta, 3.1V6. Yesterday the battery light was flickering on and off and then it would stay off so I brought it to test the battery. There was nothing wrong with the battery. So I let it go for another day and today I drove to work and the light stayed off but on my way home the light flickered and stayed on this time. So I would assume its the Altenator. My question is, I was told that it could be the voltage regulator which would be a lot cheaper to replace should I do that or should I just replace the whole altenator? Is there a way to test the voltage regulator.
May 2, 2008 at 9:57 AM
JADO351
  • 9 POSTS
if you have a volt meter see what voltage it is putting out, should be around 14 volts or You can take the alternator to a parts store and they can test it for you, the regulator is built into the alternator
Jul 5, 2008 at 4:54 PM
