1995 Chevy Beretta blowing cold air
165,000 MILES • 6 CYL • FWD • AUTOMATIC
REBEL1
When the engine is warmed up.. the motor reads hot but yet blows out cold air.. When the motor reads cold it blows out hot air. Both of these occur with the temp selector in the hot position.
Jan 18, 2008 at 11:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote:caa474c53b="rebel1"]Heater problem
1995 Chevy Beretta 6 cyl Front Wheel Drive Automatic 165000 miles
When the engine is warmed up.. the motor reads hot but yet blows out cold air.. When the motor reads cold it blows out hot air. Both of these occur with the temp selector in the hot position.[/quote:caa474c53b]
Low coolant level and air bobble will do that make sure you bleed the system and add coolant
Jan 26, 2008 at 2:09 PM
