1995 Chevy Beretta
FUDTAM
Electrical problem
1995 Chevy Beretta Front Wheel Drive Automatic
The headlights will not work, we have tried replacing the headlight switch and now were going to try the relay, do you have any advise on fixing it or what to do next?
Nov 16, 2009 at 8:52 AM
  • 110,246 POSTS
Do they work if you pull and hold the high beam switch as if you were changing to high beams? If so, check the switch. If they still don't work, make sure the fuse is good and then you need to start looking for broken wires. Most likely they will be in the steering column.
Dec 21, 2009 at 1:07 AM
