1994 Chevy Beretta won't turn over
JEREMY_28
Engine Performance problem
1994 Chevy Beretta 6 cyl Two Wheel Drive Automatic
my 94 beretta wont turn over it sound's like the battery is going dead. the battery is fully charged and alternater is new starter has been tested and is fine. its driving me nuts. any ideas
Apr 6, 2010 at 11:50 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Apr 6, 2010 at 5:04 PM
JEREMY_28
it has a little power but wont turn all the way over.
Apr 7, 2010 at 3:24 AM
  • 75,988 POSTS
If the battery and connections are good and you short out the starter motor solenoid this will crank the engine over without lagging-if it lags the starter overrunning clutch could be slipping
Apr 7, 2010 at 6:39 AM
