1994 Chevy Beretta FUEL PREASURE
103,000 MILES • 6 CYL • FWD • AUTOMATIC
DAKOTAMAN2008
  • 6 POSTS
I HAVE HAD THE FUEL PSI CHECKED IT IS HOLDING 35 LBS OF PSI BUT WHEN I HOLD THE THROTTLE ABOVE IDLE THE FUEL PSI DROPS ,I WAS TOLD IT HAD A BAD FUEL PUMP.THE CAR WONT IDLE AT ALL AND THE HOTTER IT GETS THE WORSE IT GETS ,THANK YOU
May 22, 2008 at 10:48 AM
  • 75,988 POSTS
The pressure is gonna drop a bit because the injector/s are opening and closing. Inspect and test the idle air control valve, the EGR valve MAF/MAP sensors to include the TPS sensor.
May 22, 2008 at 11:13 AM
