1994 Chevy Beretta Coolant
EHTESHAM3691
Engine Cooling problem
1994 Chevy Beretta 4 cyl Two Wheel Drive Automatic 100K miles
My car is heating up and i cant figure out where the coolant is in the car, i bought the car from someone so i dont have the owners manual. Do you have any idea where it is, is it the one saying dont open when hot over 15psi?
Apr 11, 2010 at 5:42 AM
LEGITIMATE007
  • 5,121 POSTS
that is correct. never open when hot. also the radiator cap is located at the same area where you have to stick you fingers in to open the hood. once you open the hood, look towards the left slightly or it may be right there in the middle. that cap is your radiator cap that is where your coolant goes,it should be full. also your gauge may be at hight temp but that does not necessarily mean its overheating, the sensor for the coolant could be gad. so top off you coolant and let me know what happens
Apr 12, 2010 at 1:20 AM
