1994 Chevy Beretta car trouble
200,000 MILES • 6 CYL • FWD • AUTOMATIC
AMANDAELL
Hello, I'm having problems with my car. It keeps shutting off in the middle of the road. The coil pack assembly has been changed. What could cause the car to shut off going down the road?
Feb 26, 2010 at 12:08 PM
LEGITIMATE007
  • 5,121 POSTS
could be a couple of things, but mostlikely the crank position sensor is your culprit, you could have a problem with gas or spark, your crank sensor has to do with spark. you should verify that you have good fuel pressure that will tell you if your fuel pump ,fuel filter , and pressure regulator are working, and the spark will tell you if your wires.plugs coilpack etc are working. I will send you some video on how to check these things
joe
Feb 27, 2010 at 2:01 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
this will show you how to check your spark
Feb 27, 2010 at 2:02 AM
LEGITIMATE007
  • 5,121 POSTS
this is for your fuel
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Feb 27, 2010 at 2:03 AM
LEGITIMATE007
  • 5,121 POSTS
this will show you how to change your fuel filter. which can also be the culprit, simple fix, the filter is probably under ten dollars
https://www.2carpros.com/how_to/how_to_change_fuel_filter.htm
Feb 27, 2010 at 2:05 AM
