1994 chevy beretta 3.1 z26 158,000 miles
FODE
why is our car coolint bubbling back out our resavor?we have checked our thermostat,the fan,flushed the radiator,checked the hoses,no white smoke out the exhoust.no compisation in the motor,water pump is working.
Jul 1, 2007 at 3:34 PM
EUGENE123
  • 273 POSTS
you have air locked in your water system. those motors are for what people call air locked which means in your water lines somewhere you have air. the way to fix this loosen your bleeder valve and leave it loosened until coolant starts coming out of it it may spit and sputter the coolant out for a few mintues but let it do this until you have a constant stream of coolant then tighten the valve back down. the bleeder valve is located to the left of your oil cap its small and gold looking you turn it with a flat head screw driver
Mar 13, 2009 at 3:22 PM
