1993 Chevy Beretta confused
1993 CHEVROLET BERETTA
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
KRISTANMARIE02
My car likes to stall when i go to stop, but not all the time. I don't know what to do. I also would like to know what the thermostat is supposed to read, I've heard it is at the half way mark.
Mar 2, 2008 at 7:46 AM
BLACKOP555
  • 10,386 POSTS
it can run anywhere in the NORMAL range, or a little above 1/4 and a little under 3/4 of the full guage.
Half way mark is idle but it can be higher or lower.
When your vehicle trys to stall when you stop is most likely due to a weak fuel pump, bad fuel pump relay, or a plugged fuel filter.
Mar 2, 2008 at 12:10 PM
