1992 Chevy Beretta replacing CV Joints
COOKL
Drive Train Axles Bearings problem
1992 Chevy Beretta 6 cyl Front Wheel Drive Automatic
I have a 92 beretta which is giving me troubles. I was able to get the CV joint out of the outer sides but not from the transmission. They act like they are stuck. I've replaced CV joints before in other cars and usually they come out fairly easy, but this one has me confused. cound you please tell me the best way to get these CV joints out so I can put the new ones in? Thanks for your help!
Aug 22, 2010 at 10:56 AM
HMAC300
  • 48,601 POSTS
get a big scredriver or pry bar and get it between the trans and joint and give it a good tug it should come out. You should replace the trans seal when doing this as well........
Sep 14, 2010 at 10:55 AM
