Hi there,
Thank you for the donation.
What you will have to do first is see if the engine has seized, try and turn the engine over on the stater with out any spark plugs fitted, if it wont turn on the starter try turning it by hand. Check that it has not run low on oil or coolant, if the motor has seized it will have to be dismantled to inspect the damage before any estimate on repairs can be made. If the motor still turns re post your findings and we will investigate this further.
Mark (mhpautos)
SPONSORED LINKS
Sunday, August 3rd, 2008 AT 5:11 AM
