1992 Chevy Beretta cv joint cover closest to tire
TRIPNCREATURE
Suspension problem
1992 Chevy Beretta 6 cyl Front Wheel Drive Automatic
I need simple steps explaining how to ....after I remove tire and wheel hub..?? thank you
Jul 14, 2008 at 10:35 AM
MERLIN2021
  • 17,250 POSTS
Change the axle shaft, or you will do it again!
You'll need a socket large enough to remove the axle nut, and a tool to break the ball joint free. Then just pull the strut rotor and all outward until the cv-joint clears the knuckle, I would change the whole shaft, Reanufactured axles are pretty cheap, and it's quicker and easier than messing with seperating the old joint! Use a bucket under the inner joint to catch any tranny fluid that might leak out! If you have trouble with the inboard joint, use to large flat blade screwdrivers, or prybars and pop it out of the differential...
Jul 14, 2008 at 10:45 AM
