Engine Performance problem
1991 Chevy Beretta 6 cyl Two Wheel Drive Manual
Ok i have a 91 chevy beretta. ok it hasnt wanted to start in awhile. but today it started fine. but then it started missing out real bad and when i put it in nutrual or push the clutch in the rpms drop to about 500 and dies. i've changed the fuel pump, fuel filter, cleaned the post on the battery, changed the crank sensor, its getting spark, and the fuel pressure is right where it should be, and the injectors are working, and changed the ECU. so i have no idea what could be wrong. What could be wrong? please if anyone can help me please i need all the help i can get. thank you in advance for your help.
Sep 28, 2008 at 10:29 AM
