1990 Chevy Beretta turning signals
NEEDHELPPP
Electrical problem
1990 Chevy Beretta 6 cyl Front Wheel Drive Automatic
IF I Put the switch in a certain position the turning signal will come on but it wont flash. They work if my hazard lights are on though. Is it the switch or just a short?
All the bulbs are fine, and the fuses are not blown or missing. A little plume of smoke comes out of the steering wheel if i am holding the switch for the light to come on.
Aug 22, 2008 at 1:41 PM
  • 110,248 POSTS
Hi:
It sounds like the turn signal switch needs replaced. The steering wheel needs removed to do so. If your car has a driver's side air bag, I recommend you have someone trained do the work. If there is no airbag, it will be safe for you to try.
Let me know if you have any questions.
Oct 30, 2008 at 12:12 AM
